2.3L All steel XE / Redtop engine - brand new
2.3L Vauxhaul XE built by AP Racing Engines. (http://www.apracingengines.co.uk)
Priced to sell at £8000
The nice guys at AP Racing Engines have the full build photos on their facebook page
See the link:-
https://www.facebook.com/pg/APRACING...36710963062691
This engine is brand new and has never run
Short engine
88mm bored block
New 94mm stroke Farndon steel crank
New Swindon short steel rods
New Coswork slipper pistons and rings
New ARP head, main bearing and rod bolts
Dry sump front cover and sump pan
Titan dry sump punp - not fitted and needs piping up.
Poly V front pulley with timing wheel and front mounted crank sensor
Light weight flywheel and AP twin paddle clutch - needs fitting
Starter motor (Standard)
New alternator
Head
AP Racing phase 3 CNC machined cylinder head.
35.5mm inlet valves, 31mm exhaust valves - 5.5mm steems
Head modified for high lift cams - Dropped seat area and cam lobe clearance
Rally cams
Adjustable cam pulleys
Tony Law exhaust manifold for mk 2 escort fitting
A selection of gaskets included
Engine was built about 5 years but has been kept in dry cellar and regularly turned
I would expect in the region of 300bhp or more from this engine - much cheaper than a millington!!
Prefer buyer collection but could ship on a pallet at buyers expense
Re: 2.3L All steel XE / Redtop engine - brand new
