Re: adjustable fuel pressure regulator on V6 BOA
so like robrs advised on fordpower:
"Fuel pressure regulator is the one on the fuel rail at the injectors.
The part on the fuel line in and out are pulse dampers."
So and now the big question - can i cut of the original fuel pressure reg. (somehow fill the hole) and put back the fuel damper and it should work ? ...or?
any ideas...?
