Results 1 to 2 of 2
Thread: L8 ecu on a big escort turbo loom.
    Jun 2009
    eastertown
    Hello, my first post here, can some one help?
    I am building up an Escort Cosworth motorsport shell. The engine is a home built 2.4cc unit that runs 405 BHP /440 ft lbs @ 5700 rpm on greys and a t 34 at 23 psi. It was mapped by power engineering a long time ago when I had it in my 4x4 sierra on an L8 ECU.
    The motorsport shell has a big turbo Escort loom but will it support the the L8 ECU with the 2.4 cc map. There is no lambda sensor on my turbo either so does this effect the wiring at the ECU plug etc.
    I would like to use the L8 if poss as it works so well rather than going for p8 and a remap, any suggestions or advice would be appreciated.
    Regards Paul
    Clint's Avatar
    Jul 2001
    898,842
    67
    Re: L8 ecu on a big escort turbo loom.
    Yes the L8 will work no problems.
  3. The Following User Says Thank You to Clint For This Useful Post:
