Only part I haven't replaced on my car,s a 2000,is the coil,read up about ballasted and .
my car is a 1978.
checks I've done so far.turned ignition on .getting 12v at positive side of coil,as loom has been re taped no idea if it has a resistor in it.
cleaned old coil up and has the following details on it.
dq124 12v.oil filled coil.?as car is an import no idea if it's original or not.
also running a std engine with motorcraft distributor .
any help cheers murf.
