Results 1 to 17 of 17
Thread: compressor help
    Mechanic madboy's Avatar
    Nov 2007
    on a road to nowhere
    542
    10
    Question compressor help
    was useing my compressor today and the air was getting low but the motor would not cut in ,so i shut it of to restart it and it wont start up it sounds like the motor is trying to ingage but it wont turn over, there what looks to be a coil pack ontop of the motor ,iy smells a bit dodgee anyone help
    Attached Thumbnails Attached Thumbnails DSC00288.jpg‎
    DSC00289.jpg‎
    MADBOY!!!
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: compressor help
    I think that coil is a capacitor. Touch the terminals and you will find out (do not do it!)
    Sounds a bit like it might be that bit that is knackered. Best get a sparky to have a look really.
    I support TS Decade Plus User
    alladdin's Avatar
    58
    9,959
    150
    Re: compressor help
    you can get a start capacitor from a city electrical outlet amongst others, have you removed the belt to check if motor spins ok by hand ?
    Nov 2007
    542
    10
    Re: compressor help
    yer,you can turn the pullys and they rotate easy,please any help very muck appreciated
    MADBOY!!!
    alladdin's Avatar
    58
    9,959
    150
    Re: compressor help
    switch it on with your hand on the motor (safely !) does the motor hummmmmmm ? or does it blow the fuse / trip out ?
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: compressor help
    Switching it on with your hand on it when you know there is a problem is not the best idea in the world.
    Get a sparky to have a look at it!
    Whatever it costs it will be a lot cheaper than a new compressor or a funeral.
    Nov 2007
    542
    10
    Re: compressor help
    if you switch it on you can clearly hear it humming but it doesnt trip or blow fuses
    MADBOY!!!
    Spanner Monkey Dazzer76's Avatar
    Jul 2009
    Billericay
    208
    Wink Re: compressor help
    try maplins there great for all things like capaciters , if its readable there should be a microfarad rating and voltage of the unit ,failing that get on to the company who made the compressor via phone and ask for the details .....once you got the spec on the capacitor ,,,maplins or an rs components store will be able to give u a relpacement
    DO NOT TOUCH THE TWO ENDS your get a proper whack !!! short the two terminals with a insulated screwdriver ( with the unit UNPLUGED)
    hope this is of some help
    dazzer
    Apr 2004
    manchester
    860
    33
    Re: compressor help
    i've got an sip ( direct drive) compressor... mine did the same... it wouldnt fire up.. just made a hummmmm,,,
    it was the starter capacitor... it had blown it's self to bits
    anyway a new one did the trick.. but now the rings have gone.. doh !!!
  10. The Following User Says Thank You to chrisb For This Useful Post:
  11. #10
    Nov 2007
    542
    10
    Re: compressor help
    Quote Originally Posted by chrisb View Post
    where did you get it from
    MADBOY!!!
  12. #11
    Jul 2007
    reading
    113
    Re: compressor help
    reading pnumatics do them about 15 each
  13. The Following User Says Thank You to avopaul For This Useful Post:
  14. #12
    Apr 2004
    manchester
    860
    33
    Re: compressor help
    got mine from excel compressors in hyde ( gt manchester ).. All you need is the numbers off it...
    cheap as chips...
  15. The Following User Says Thank You to chrisb For This Useful Post:
  16. #13
    alladdin's Avatar
    58
    9,959
    150
    Re: compressor help
    dave wont like this
    when its hummin , try giving it a spin on the pulley in the correct/normal rotation. if its the starter cap then it will probably spin up to speed when you give it a head start
    edit, dont do this with the belts on as it might grab you
  17. #14
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Re: compressor help
    FFS
  18. #15
    Nov 2007
    542
    10
    Re: compressor help
    Quote Originally Posted by dave View Post
    ffs
    :d
    MADBOY!!!
  19. #16
    Pit Crew boombang's Avatar
    Mar 2006
    Essex
    1,124
    Re: compressor help
    Is this a 13 amp unit on regular plug?
    If so is there anything else that's just been plugged in on the same circuit?
    I had to put a new ring off the mains for my garage, otherwise the compressor did as you said - buzzed but didn't start running.
    Quote Originally Posted by boombang View Post
    Not entirely sure what point I was first trying to make or even sure what point I have made.
  20. #17
    Nov 2007
    542
    10
    Re: compressor help
    thanks for all your help guys,got the part from reading pnumatics only cost 50 took 3 days for the part,highly recommened them
    MADBOY!!!
