Results 1 to 9 of 9
Thread: Big winged sump vs Dry Sump
    Jan 2005
    Cambs
    1,088
    17
    I'm aware of he differences of each of these but has anyone used a winged sump on a Mk2 S2000 conversion without having to modify the crossmember ?
    I haven't removed the sump off my engine yet but I'm guessing a new sump and pick up could be made to use one for a LOT less than a complete dry sump setup.
    I have read that the F20 does suffer from oil pressure related issues on track so is this is a pump issue or simply the sump not being adequate for hard cornering ?
    I'll be using the JEMS Xmember if that makes much difference to the clearance issues
    Mechanic waynemk2's Avatar
    Dec 2005
    Wales
    802
    28
    Re: Big winged sump vs Dry Sump
    Hi i did try and find a way of using a wet sump. but found that due to the position of the engine i wanted, the oil pump was bang in the way of the steering rack and XM..
    As i wanted the engine far back and low as possible i had to dry sump it..
    cheers
    Jan 2005
    Cambs
    1,088
    17
    Good info cheers, what is used to blank the oil pump when dry sumping the F20 engine ?
    Have you got any pictures ?
    I'm going to just have a pan made after getting a price on one !
    Dec 2005
    Wales
    802
    28
    Hi have a look at my project in the resto section im sure i put pics up of putting the pan on..
    Pit Crew Decade Plus User PaulAlex's Avatar
    May 2006
    South East
    1,561
    175
    Hi Jon,
    It might be worth you contacting Jonnie Wigmore on here - he's got an S2000-powered Escort up-and-running without a dry-sump, and it seems to go very well without an problems. Somehow, it sits s low as my dry-sumped setup too!!!
    Cheers,
    Paul.
    Dec 2007
    bicester
    247
    the dry sump pan does not realy allow the engine to sit any lower, maybe 10mm max. The problem with wet sump is getting the engine to sit back far enough. We cut a bit out of the sump allowing the engine to sit back as far as poss retaining the std oil pump. Seems to work very well
    Jan 2005
    Cambs
    1,088
    17
    Thanks for the info guys, I still think I will be more comfortable with it being on a dry sump simply as its a circuit/sprint car.
    Apr 2004
    Bangkok, Thailand, Thailand
    5,527
    489
    Does anyone have any pictures of an engine in the bay with a wet sump? And pics of the sump too
    Bodger evobda2's Avatar
    Sydney, Australia
    180
    Id love to see pics of this.. as if i can get away with this, it may be the one thing that convinces me to do a f20c in my mk1 road car!
    Quote Originally Posted by jonnie205 View Post
