Results 1 to 5 of 5
Thread: Exh. Manifold Fouling Sump
    Spanner Monkey haz87's Avatar
    Aug 2012
    Colchester
    218
    Hoping someones got their imagination hat on as I'm in need of some ingenuitive/cheap ideas!
    ZVH engine so CVH (n/a) Magnex manifold and Zetec silvertop sump.
    Clearly twatted the road a few too many times and so the manifold is now sitting against the corner of the sump and is making a horrible resonance at certain RPM (not to mention probably sending a load of heat into my oil).
    I can lever it away from the sump with a pry bar and wedged some exhaust wrap in there but the tiny vibrations just wear through this in no time. Went out and bought a 5tonne ratchet/tie-down strap and used this Friday morning (after a run so the system was nice and hot) to pull the manifold away from the sump. This created a good ~1cm gap all round and have left it like that for the last 2 days hoping the manifold might at least take "some" of the form it was being held in.
    Released the strap just now and of course its just pinged back where it started
    Anyone got any thoughts as to what the hell else i can try?
    Cars a daily so whipping the sump off and getting the corner cut/tigged is not an option (plus reducing sump capacity etc isnt where i want to go for what is essentially an "annoying vibration") and the Manifold is fine other than this so again don't want to be buying new either.
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Re: Exh. Manifold Fouling Sump
    Can't you make a part hacksaw cut (about 3/4 of the way round)in the pipe just before the place where it hits the sump, bend it to close the gap and then weld it?
    25,110
    the only way your ratchet strap idea will work is if once you have strapped it you use an acetylene torch to heat the manifold red hot so it relaxes into the strapped position.
    a cheap fix might be buy a manifold flange and use it to space the manifold away from the head
    Aug 2012
    Colchester
    218
    I did consider this Graham. I haven't got access to Oxy, have got plenty of MAP and a decent torch. Do you reckon that would have any effect or would i just be wasting gas...?
    25,110
    having bent plenty of exhausts in my time you probably wont do it without oxy as you need to get the manifold almost white hot before it will bend
