Hi all after some advise. Just bought low mileage st170 engine. Unknown history. Thinking of either strip it and check bores and rering it. Or bore it out to 86.5mm to make 2.1. Ideas or advise please.
Anybody
If it were mine I would strip the unit and check the wear - then make the call on which direction to go.
John
ive got one here i stripped for someone supposedly low mileage it was mint inside. i would suggest doing a compression test, if all is well leave it alone and spend the cash on bolt on bits which will actually make the most of it
Thanks for all the reply.s
Been thinking fitting new shells and oil pump. Belts and away to go. Just got to make it fit then
i have one coming my way soon that i will be selling if you find you need another or a spare and i agree with above, strip and check then either reassemble or buy another ! they will hit close to 200 bhp standard if mapped correctly.
Thanks for info. But I'm struggling to find any st170 engine specs, stuff I can use when stripping to measure / compare up against,
E.g., compression test figures
Piston ring gaps
Torque wrench settings,
anything engine related
Any help peeps
Sent from my SM-T560 using Tapatalk
i would split the bearings and if they look ok chuck it in and take a chance you will still need torque settings tho.
Couldn’t agree more with the above....
They’re a cracking engine and wear very little! See links below for your torque settings and bearing measurements
https://cdn.fbsbx.com/v/t59.2708-21/...=5AD66FCF&dl=1
https://workshop-manuals.com/ford/fo...pecifications/
St170 rebuild. My new rebuilt engine, st 170 base, New pistons, decked block, Arp bolts. Uprated oil pump, bal and lightened. Zx9 ninja bike carbs, all painted .
Awaiting on sump and race manifold,
Can't wait to fit this in my project.
I think those Boggs Brothers inlet manifolds are why some bike carbs work well on cars - the tract length is about 3 times longer than on a bike - long inlets = torque............just an observation. Very Italian colour mix lol!
Some more pics
Just bought these as well.
Hopefully these should help me STOP
Looking good mate, what manifold are you going for?
I fancy a nice stainless one but can’t justify the cost at ye minute, my motor has just made a healthy 240 horse with a Ashley one
St 170 rings are hard to get I am wondering if 2.0 zetec ones can be used on st 170 Pistons
Hey a very intrested Projekt. I need to buy some of Exhaust valves for the st 170 cylinder head and i found nothing. Can you help me?
Need to look harder LOL!............ https://www.onlinecarparts.co.uk/ipsa-7255894.html
