Hi All, Can anyone please tell me the length of the BMW 46mm M10 inlet valve.
cant find any 46mm valves at the moment, but i measure an oversize 48mm valve, that was 104mm from face of head to tip of stem
Thanks Graham, I'm looking for a larger valve for the Cologne. Not sure whether to use the M10 valve or the M30 valve at this stage.
i just found a 46mm valve that was same length as the 48. m30 is a different length somewhere i have a book which will tell me
ford valves from that era tend to have very thick , so the effective difference between the ford and bmw may not be as much as the numbers suggest.
you could always shorten the rocker posts a bit
