Results 1 to 3 of 3
Thread: Mk2 Escort Horn Wiring Problem
    Racer Decade Plus User x-pack's Avatar
    Mar 2006
    Leyland, Lancs
    2,102
    169
    Hi
    my horn has packed up and i need to test the switch. What colour are the wires that go to the switch? I have a wiring diagram in the Haynes manual but the print is so tiny that i can't see what the colours are
    I've tested the horn and that works fine but i can't trace a live anywhere. I figured that i might as well start at the switch. Any other suggestions??
    I'm going to pull your head off because i don't like your head!
    Mar 2008
    manchester
    733
    Re: Mk2 Escort Horn Wiring Problem
    hi, ive not long gone through the wiring on a mk1, so urs wont be much different. try the fuse box first, them crappy fuses were always letting me down with bad contacts. ive now moved on to the blade type, and found them far more reliable. really cant remember the colour, all i can remember is that it is different at the switch than it is at the horn itself. am also sure that it shares its live feed with something else, get urself a little multimeter ad get prodding!
    Nov 2003
    Wirral UK
    7,322
    259
    As above, twiddle (technical term) all of the fuses in the fuseholder, I'd bet you've got a bad connection in there.
    http://escort.accelerator.org
