Results 1 to 8 of 8
Thread: Type 9 Reverse Switch Thread
    Nov 2008
    Adelaide, Australia
    1,331
    96
    What is the thread on a Type 9 gearbox reverse switch? Took the old one to the hardware store to test it on their thread checker board but it only goes up to M12. I assume it is M14????? Just want to remove the switch and blank off the hole with a bolt. Don't want to use silicon.
    4,889
    Re: Type 9 Reverse Switch Thread
    Is that the same thread as a Type E reverse switch?
    That's M14 fine, if you just want to plug that hole a 9/16 UNF bolt will probably fit good enough.
    Jun 2004
    Bristol
    1,494
    18
    Why do you need to blank off the hole? There's no oil back there
    Nov 2008
    Adelaide, Australia
    1,331
    96
    M14 fine
    No oil but I want to keep the krud out.
    Just leave the switch in ??
    Nov 2008
    Adelaide, Australia
    1,331
    96
    was getting in the way when removing the box.
    fair enough.
    Oct 2008
    whitley bay
    2,436
    89
    You can cut the switches down and they have a hex inside them as they were prone to snapping
    Hexham and District Motorclub
