Re: 4x4 Sierra front axle pics please?
Thank's m8.
got this pic of the engine box and front end still on the crossmember, its the boring side to look at though, the diff is mounted on the other side of the sump with the gearbox having an added in section to house the chain driven transfer case on the same side a short prop going forwards to the diff, this visible side driveshaft passes right through the sump.
