Results 1 to 20 of 20
Thread: Hydraulic clutch kits for Type 9 box
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Has anyone used one of theses kits from Motorsport tools or know of another that works well in a tpye 9 box ?
    https://www.motorsport-tools.com/esc...et-type-9.html
    Jan 2008
    Milton Keynes
    137
    Re: Hydraulic clutch kits for Type 9 box
    I use the retro-ford one
    http://www.retro-ford.co.uk/shop/con...ring-kit-bc002
    The slave I believe is off a Mondeo/galaxy
    Quote Originally Posted by nbs View Post
    Mine was from burton power but I think they all come from the same source. I have one on my anglia and mk1 escort. On the escort I blew the seal out. Hindsight I think it was a wrongly sized master cylinder. The anglia one has been perfect.
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    What size is the master your using ?
    I think 0.625 now but I can’t check as I am away working but can confirm at the weekend.
    Jan 2008
    Milton Keynes
    137
    Standard MGB one works perfectly fine with mine, no idea of the size though
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    If you could check and let me know that will be great
    Retro Ford recommend 0.625 with their slave cylinder kit.
    Will do. But pretty sure 0.625
    Jan 2013
    bedford
    Hi all, I’ve just fitted one of these kits to my mk2 esco with type 9 alongside a new helix fast road clutch kit. I do however have a problem which is that my pedal is getting massive resistance when pressed. The pedal stops dead after 2/3 inches as if the bearing is hitting a wall. On bleeding the pedal is fine. It looks like the slave cylinder is working ok, I’ve spoken with motorsport tools but to no avail. I have a 0.70 master cylinder, could it be this? Should I use a 0.625? My pedal is also very high when fitted but thought this could be adjusted on bleeding and on the thread?? I really ha e no idea.....anyone have any ideas or experienced this?....
    25,110
    the .7 cylinder will give you short travel and a heavier pedal
  12. The Following User Says Thank You to Graham For This Useful Post:
  13. #12
    Jan 2013
    bedford
    Ok great thanks, so do you think a 0.60 or 0.625 may solve my problem?
  14. #13
    You need to try a 0.625 cylinder to reduce the volume of fluid to the slave cylinder/release bearing. Don't force the pedal because you'll push the clutch plate diaphragm over centre and do damage and there's also the chance of the cylinder pushing it's self out.
    Even with the smaller master cylinder you might have to fit an adjustable clutch stop to the pedal to stop it travelling too far.
  15. The Following User Says Thank You to Forest_rallying For This Useful Post:
  16. #14
    Thats exactly what i did with the wrong master cylinder. Just checked the anglia and defo 0.625 as supplied by Milton and works fine. I have put a 0.625 on the escort but never tested it yet, I have no reason to think it won't work now.
    I may get to bleed it this weekend. I can confirm what size i originally used shortly if its is worth it (just need to find it) it is somewhere safe.
  17. #15
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Could you let me know what size didn't work ? Cheers
  18. #16
    25,110
    anything bigger than .625 will be too big and dammed heavy
  19. #17
    I found the old cylinder and it was a 0.750, why i will never know and no wonder it pushed the release bearing right out
  20. #18
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    Do you recon a 0.70 would be ok ?
  21. #19
    25,110
    FOUR people have replied you need a 0.6 that might be a clue as to what size you need!
  22. #20
    Bodger nbs's Avatar
    Aug 2009
    Bristol
    64
    OK OK keep your shirt on. Only double checking as its not a Ford ive got Only using Ford engine & box.
