Anyone out there in turbosportland willing and able to convert my 2.9 XR4x4 to AJ30 power?
It's not an engine guru you want it's a company willing to do an engine conversion. ( guessing as I have no idea what the aj is)
The AJ30 is a 3.0 L (2967 cc) version and is the most common, especially considering the Duratec 30. It has an 89 mm (3.5 in) bore and shares the 2.5's 79.5 mm (3.1 in) stroke. In the X-Type, it produces 231 hp (172 kW; 234 PS) and 209 lb⋅ft (283 N⋅m). The Jaguar XF debuted a refined version of the AJ30 with continuously variable cam-phasing and variable geometry air intakes to increase power and broaden the powerband up to its 6800 rpm redline.
