hi guys, after many weeks playing with the fueling problem i have now ditched the rs carb and fitted a renault 5gt turbo solex, it now runs a dream with no spluttering and no longer running rich, the problem i have now is in 3rd and 4th gear at the higher rev range it seems to starve of fuel, im using a new facet fuel pump and only running 10 psi of boost at the moment, does anyone know what psi of fuel presure the solex can handle as i have a xr3i pump wich produses 40 psi and when i fitted with the rs carb it blew the reg valve and the carb to bits and i dont want to do the same again, or do you lads think its not fuel presure thats the problem, maybe re jetting or something completley different, all ideas welcome, cheeRS Edd.
