As per the title, anyone fitted a throttle position sensor to either a 32/36 dgav or 38 dgas carb? If so, what sensor did you use and how did you mount it?
I think I have a picture of such setup, I'll try to find it again...
Found it, it's not on weber but on linkage, nice and clever.
https://i62.servimg.com/u/f62/15/62/31/37/a7214910.jpg
https://i62.servimg.com/u/f62/15/62/31/37/a7215010.jpg
Thanks for the photos. Never thought of putting it on the linkage - clever, you don't have to mess with the carb itself.
This is mine I made up. I made a little extension shaft to fit on the original spindle, that goes into the TPS.
nice one as well, do you have pics at other angles ?
The white plastic thing holds a small bearing and supports the extra shaft. Both the bearing and TPS came from a blacktop inlet manifold, but I can't remember if it was a Focus or Mondeo one. I made the plate up myself and had it annodised.
thanks.
And really nice job.
Thank you. I had Mr Webcon(UK) himself looking at it very closely not so long back too. Wanted to copy/improve the idea, but not seen anything from them. Not sure how big the demand would be tbh hence why I never bothered to do it myself either.
Thanks for another method of adding it
