Results 1 to 7 of 7
Thread: Blacktop Zetec and alloy upper sump
    Feb 2018
    uk
    Question Blacktop Zetec and alloy upper sump
    Hello, hopefully someone can answer my question.
    Im building up my blacktop Zetec for my Mk1 Escort thats got the retoford world cup cross member, and i really need to keep the aluminium upper sump. Is this possible, and does anyone know or is anyone on here able to modify the steel part?
    Many thanks
    Trev
    3,239
    Re: Blacktop Zetec and alloy upper sump
    Generally no! To get the sump shallow enough to fit over the x-member you have to mill off virtually all of the integral windage tray then have to flat plate it. Easier to get a purpose made or modified sump IMO.
    Bodger skandimike's Avatar
    Apr 2013
    Billingham
    115
    Hi I have just fitted a blacktop into my mk1 and to be honest the retro ford alloy sump is the way to go.
    9,204
    As above. The alloy can be used in kit car etc with no xmember but even then the steel part needs modding
    Feb 2018
    uk
    Thanks guys. I did have my eye on the retro Ford one, but im building a zetec turbo so will have to get a oil return installed.
    Thanks again
    Trev
    3,239
    Quote Originally Posted by gotty101 View Post
    No need to go to sump - there is a crankcase breather, exhaust side, that could be modded to take turbo drain?
    Feb 2018
    uk
    That's a good point, easily above the oil height and no messing about with the new sump. I need to read up on the breather requirements for a zetec turbo.
