Results 1 to 6 of 6
Thread: Cosworth boosting problem
    May 2018
    Bournemouth
    Hi can anyone help I’ve fitted a yb engine in my Capri it runs fine till
    it gets up to temperature
    then it starts to coff and splutter and backfire on boost it runs if I drive it normal I’ve changed the plugs
    and fuel filter and fitted a fuel pressure gauge
    and the fuel pressure is fine any help will be apreshated thanks
    Spanner Monkey Alan G's Avatar
    Jul 2005
    Ireland
    363
    21
    Re: Cosworth boosting problem
    Worth changing your coolant temp sensor at the back of the head.
    https://shopbhp.com/collections/temp...e-sensor-wts05
    25,116
    do you know the history of it all?
    turbo, injectors and map sensor all have suit the ecu/chip inside it
    Oct 2015
    Essex
    347
    33
    Try the phase sensor inside distributor check the wire insulation not gone bad :-)
    May 2018
    Bournemouth
    Quote Originally Posted by Ianbavs View Post
    I’ll have a look but I don’t know how to use tapatalk
    May 2018
    Bournemouth
    I’ll try that first Cheers
