Results 1 to 5 of 5
Thread: Keeping the boot open
    Spanner Monkey Kmp's Avatar
    Feb 2009
    Burnham on sea
    390
    Hi all,
    i have cut my head open twice in a short space of time where I go to grab something out of my boot and the lid smashes down on my head!! Getting a bit fed up of it tbh, don’t want to have to wear a helmet to get something out the boot. I see there are two rods under the parcel shelf, can you adjust them somehow to strengthen them to be able to stay open?
    thanks
    kris
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    Re: Keeping the boot open
    Hi Kris,
    You will see at either end where the rods are that you can move the rod (both sides) to a further back 'peg' this will increase the torsion on the rod and should keep the bootlid up!
    The issue is usually when a car has a spoiler fitted, and it is tensioned for one without.
    Hope this helps!
  3. The Following User Says Thank You to Duffer For This Useful Post:
    Kmp
    Feb 2009
    Burnham on sea
    390
    Thank you for that, I will have a look in the boot, I do have a spoiler fitted which I know is the reason for the boot closing. Also worried I will drop my keys in the boot and it will slam shut lol.
    Kris
  5. #4
    Feb 2009
    Burnham on sea
    390
    I have just checked and the boot is already adjusted to the tightest setting, so I guess I need a helmet or a prop lol
    Kris
  6. #5
    Jun 2006
    kilkenny, ireland
    519
    Quote Originally Posted by Kmp View Post
    Kris
    You should be able to turn the rods one more rotation with a bit of grunting… this will increase their tension significantly.
    Just unhook one rod and twist it 360 deg against its natural rotation until you can get it hooked in again, tensioning just one of the rods like this might be enough to hold your boot open.
    Be warned, its not easy to rotate it and if it slips it can pinch or slap your hand or fingers, which isn’t nice.
