Re: 2.0 Zetec Turbo Westfield Project!
stick at it !
Is that a -8an fitting on the block breather plate or bigger??
How did you get away with painting the block on the dining table??????
Great read. Thanks for posting.
turbo m - Its an AN10 fitting, will go to the bottom of my catch tank, the rocker will also be AN10 going to the top of the catch tank. Then there will be a tiny filter off the very top of the tank to vent to atmosphere. The Block breather will act as a breather/drain back to the sump when engine isn't running. I'm still wondering how i got away with it! It was her idea!
The Following User Says Thank You to nickharding For This Useful Post:
