Is there a guide to coverting to an atlas?
I've searched threw 7 pages on atlas axles but cant find anything on actually fitting one.
Its a mk1 capri 50" item I've got, going on a mk2 rs2000 thats getting a yb.
Ive decided for just now just to run it on leaves, can i just chop everything off my rs axle and weld them on to the atlas - spring plates, tramp brackets etc, how would i go about the removal of the parts and repositioning? Would I be better getting a RACE anti trramp kit etc??
Re: Is there a guide to coverting to an atlas?
The spring plates wont fit without reshaping as the tubes are a different thickness to an english. You are best to use the ones from the atlas if possible. Tramp bar mounts should be ok as they are only small
Bugger, the atls plates have had it, dont suppose i can get replacments?
Cheers dave!!
I know Gartrac sell them. Fostek may sell them separately. Probably the likes of Rally Design, West Wales Rally Spares, Grp4 Fabrication etc may sell them.
Thanks Phil, i'll give them a try
