Results 1 to 3 of 3
Thread: pinto inlet short turn
    Jun 2015
    Australia
    293
    Hi all when modifying the short turn on inlet port on a carbi head 2 litre how wide can it be made with a flat floor 36mm or more wider can some one advise me please cheers Mario.
    Aug 2015
    Leeds
    767
    Re: pinto inlet short turn
    Have a read through this thread, graham knows his stuff, carnt rember exsaclty what info is there but it’s a good read
    http://www.turbosport.co.uk/showthread.php?t=420761
    Mechanic snapper1's Avatar
    Oct 2010
    Chelmsford
    67
    668
    27
    I think the first thing to do is work out the valve size and have the port throat under the valve seat opened out leaving the correct valve seat size.
    cutting out the port throat will cut in to the short side turn and this will be blended in to the port work from the other direction.
    this is nearly my understanding and as always I bow to those with much much more experience and understanding.
