Results 1 to 6 of 6
Thread: EEC-IV tunning myth? Forget!
    Jun 2012
    Slovakia
    You know that myth about EEC-IV tunning? Forget about it!
    EEC-IV is quite easy to tune..just need propper HW.
    This small turbo is targeting for 330BHP with 400cc injectors, T35 bigturbo
    as the MAP sensor is only 2.5 bar....here is the limit.
    Click image for larger version Name:	IMG_20180525_215647.jpg Views:	113 Size:	111.3 KB ID:	82819Click image for larger version Name:	IMG_20180525_215735.jpg Views:	114 Size:	124.5 KB ID:	82820
    Trinidad West Indies
    172
    Re: EEC-IV tunning myth? Forget!
    Thats a bit ambitious bhp on 400cc injectors.....
    What would be your duty cycle?
    Regards,
    Kevin
    Jun 2012
    Slovakia
    hope under 90
    its little bit tricky to work with EEC-IV.....nothing easy! that ecu is very clever....
    172
    No spark cut is a major drawback in terms of protection....
    Good luck with that 90 ...lol
    Regards,
    Kevin
    Jun 2012
    Slovakia
    maybe owner was more optimistic than reality is...at the end, BHP is not important Important is more power then OE injectors..
    currently I stopped on 92% injector duty and 900Kg/h on MAF so this is maximum what OE MAF can calculate...we are not going to do more.
    But generally I can say, every EEC-IV needs CUSTOM tunning!!!! that ECU is nightmare! That old ford MAFs are nightmare too....
    3 used mafs = 3x cheating mafs! car is runnig lean when maf is old!
    Jun 2012
    Slovakia
    done 1,3 -1,4 bar boost...800Kg/h at maf....400cc injectors at 92% duty with bigturbo inside...still on EEC-IV.
    it will need bigger MAF and bigger injectors.
  7. The Following User Says Thank You to midnightman For This Useful Post:
