Results 1 to 6 of 6
Thread: What radiator cap? (aftermarket radiator)
    Mechanic longboy's Avatar
    Jun 2007
    notts
    438
    12
    Hello all, i'm having trouble finding a radiator cap for a after market rad i bought years ago before the car was stood.
    I bought a standards capri/ escort cap. Doesn't fit, a bit small on the main OD doesn't touch the bottom of the neck and tabs won't go over the locking thingies on the neck.
    Long type cap touches the bottom of the neck but wont compress enough to close and thing the tab issue above is still there. Photos below:
    The neck OD is 57mm, 20mm deep with40 mm internal diameter
    Any help appreciated
    Mar 2009
    sussex
    148
    Re: What radiator cap? (aftermarket radiator)
    Im assuming your car is a 2L or 1.6 as the 2.8s dont have a spring in the cap and vent straight to the expansion tank.
    Should all be fairly standard have you tried bending the tabs on the car to fit better?
    Pic of the cap on the rad?
    Jun 2007
    notts
    438
    12
    That's the issue. It's an after market radiator I bought years ago. Didn't come with a cap, I think some filling and a washer in the bottom of the neck is needed.
    Oct 2015
    Australia
    Bumping a old thread but i have this problem currently
    Looking for a stant cap that fits this neck.
    4,894
    Looking at the dimensions above these are the same for my radiator from Ralloy.
    It has this cap:
    https://www.ralloy.com/alloy_radiato...ap/c23p13.html
    Oct 2015
    Australia
    Thanks mate, local radiator place sorted me out.
