Dellorto 45s spilt by Dave Brooke's full set up inc proper Brooke's manifold & rose jointed linkage & piper cross filter , this is a complete set up not been used since full refurbishment , in perfect order ready to fit £1300 Ono
Pinto alloy rocker cover with tig welded cable bracket to suit splits been powder coated black perfect order £150
Ashley 2 1/4 manifold 3 piece in very nice order £80
Pinto alloy bell housing with gen ford fork converted to hydraulic with new cylinder can be used with quick release also very nice £200
New ultimate heavy duty group 4 Rix eng World Cup x member with pinto / bdg mounts £325
New Rix engineering pinto alternator kit complete kit inc alloy polly v pulleys & mount £330
Pinto Alloy sump with modified baffle to prevent oil serge very nice condition with dip stick & pick up pipe £ 260
Atlas axle 4:6 cwp genuine ford absolutely mint condition £250
Baby atlas fully floating atlas casing brand new by Rix engineering , 4 link , spring saddles , turret , ap 2383 all welded on never used £600
Squires baby atlas fully floating shafts in perfect order £ 150 pair
Atlas - large English 5 speed / 4 speed new group 4 prop shaft fitted only no mileage £ 80
As new Rix eng heavy duty 4 link bars gen ford bushes £125
12 gal shaped Alloy tank powder coated satin black jic fittings new sight tube not used since powder coat perfect order £ 140
2x facet red top fuel pumps on powder coat alloy bracket with new torques manifold for jic fittings mint order £200
Bare atlas axle pigs heads with bearing caps ideal to retube Ect £150
Complete Vauxhall c20xe red top complete head bottom end , sump , rocker cover inlet manifold , loom & ecu head & sump off for inspection removed from Astra gsi £ 275
4x 205 pinto bottom ends complete with crank & rods £295 all in nice order each
4x Pinto std heads £45 each
Will post & no problem
can accept PayPal
