i am after a 205 injection rocker cover, I have read that alloy ones leak so a standard pressed steel one would be fine. I want a straight one, I have seen a few distorted ones over the years from different vehicles.
thanks
kris
thanks
kris
Actually, is there a difference between injection/non injection sized rocker covers? I have a std one, my injection head that I want to fit on the engine is away having some bits done so I can’t check the fitment on it.
Kris
wide/narrow gasket flange is only difference that i know/have ever noticed
So would a std 205 rocker cover fit a 205 injection head?
When I first looked on the internet for info, it said that there was a difference in cover size between the injection/non injection covers, but as I have delved deeper someone else has said that there is ‘only’ a difference between a 205 and non 205 rocker cover.
http://www.oldskoolford.co.uk/ipb/in...-rocker-cover/
Kris
Yes simply. There are some little shaped mounting washers to spread the load of the bolt heads.
Peugeot 205 ????
Camcovers for carb engines have a bracket for air filter housing.
Shaped washers:
If this helps
