Results 1 to 6 of 6
Thread: Escort mk2 choosing alloy hubs for my group 4 bilstein struts HELP
    Apr 2016
    Montevideo
    31
    128
    10
    i have these struts, they are bilstein group 4 maybe? i need to buy a pair of alloy hubs kit to fit my escort mk2 1600 sport, i see a lot of types in burton but not sure what hubs i need to buy
    Click image for larger version Name:	34701811_2031000693783465_3414254011090468864_n.jpg Views:	79 Size:	134.9 KB ID:	82848
    3,641
    Re: Escort mk2 choosing alloy hubs for my group 4 bilstein struts HELP
    Are your wheels group4 and do you want the 10mm wider track? if not go for std stud, std width hubs as grp4 ones give a 10mm wider track.
  3. The Following User Says Thank You to Erikmex For This Useful Post:
    Apr 2016
    Montevideo
    31
    128
    10
    my wheels are group 1 6x13, ye wider 10mm would be ok but i dont want problems fitting the struts and hubs with the calipers and disc
    Click image for larger version Name:	22539728_1929787990571403_8198810775356195717_n.jpg Views:	71 Size:	100.2 KB ID:	82853
  5. #4
    3,641
    These are what you need :
    Standard track :
    https://www.motorsport-tools.com/rix...-rs-capri.html
    +10mm track - although these ones have the larger outer bearing, rally design etc do the +10mm, std stud ones that take the std bearing also.
    https://www.motorsport-tools.com/esc...std-studs.html
    Basically, all you need is std stud ones, then choose the width bearing options you want.
  6. #5
    Apr 2016
    Montevideo
    31
    128
    10
  7. #6
    3,641
    Same things only more expensive, alot of people no longer deal with Burton anymore, poor service and poor quality parts, although these are made by Grp4 Fabrication which produce decent kit.
Tags for this Thread
