Re: Is this the hazard relay connector?
If it's a mk1 escort then this is not the hazard connector.
I'm away until monday so I'll have a look then but if I remember rightly one of the wires is black with a green spiral stripe running up it.
Thanks. Yes this is a mk1 escort. It's got the hazard bulb. Can't find the hazard relay so thought this must be it.
This is what mine looks like.
In this one you can just see the warning light also has that green spiral stripe running up it
Thanks for the pics. I searched high and low but ,could only find one flasher relay point ( every schematic I saw showed one for hazards and one for indicators). So I fitted my newly arrived hazard switch and all worked. Turns out my car only has one relay. Thank you for your help.
The schematics fooled you as these show both options (just flasher, hazards) in one drawing.
