Hi guys anyone got any dimensions or pictures of how much to cut out front bulkhead to fit 15" bowls.Bought magnum panels and the curves look similar to the original ones?
hi guys quick question please. ive got a ford cortina shell. its got the chassie number and i need to get a dating certificate to get the year it was make so i can register it to dvla. any ideas to best way to go forward with this please many thanks.
Hi, I marked mine out from the inside, it was easier this way, you sort of find a position that it fits well into, bearing in mind that you have the inner wing on the other side (ie you dont want to bowl to be in part of the engine bay!) The bowl should in effect just make the curve larger, rather than being at a different angle to the original if that makes sense?
