Results 1 to 7 of 7
Thread: What is this switch for?
    Dec 2017
    Ayr
    176
    Could anyone tell me what this switch on the dash is for? Circle with half circles each side? Rocker switch, press and hold. Symbol looks like something do with braking system but too early a car for that! Location bottom left on centre console. It is still connected up, no idea what it does?
    Dec 2017
    Ayr
    176
    Re: What is this switch for?
    Google says heater fan.
    Jan 2016
    Hull
    246
    Brake fluid level test switch, prob aftermarket. Have a look on top of brake resevoir, if it has wires going to it that's what it is.
    Dec 2017
    Ayr
    176
    Ah really! Car has a line lock fitted, reservoirs are behind the steering wheel, not easy access! Probably is for that, thanks.
    Yet to try the line lock for a burnout, scared I will break something!
    4,888
    Quote Originally Posted by Colr6 View Post
    RS2000 had such a switch as std.
  6. The Following User Says Thank You to Miniliteman For This Useful Post:
  7. #6
    9,200
    So do ghia and probably all late mk2. I think it became a legal requirement maybe ? Low level light and switch to test all in 1
  8. The Following User Says Thank You to alladdin For This Useful Post:
  9. #7
    2,656
    267
    This one always made me laugh a bit really. If your fluid level's low it either means you've got a leak somewhere or the pads and shoes are knackered. Either way you should be replacing things not just topping up fluid.
