I'm confused (just to make a change) and am trying to wade through the clutter of personal opinions to find definitive answers. (yes I have used the search function)
Reasons to Fit WCXMDid I miss any????
- stronger than the standard item and keeps the engine in the car over rough roads
- reduces engine movement and the associated negative handling impacts
- ability to fit lower rack mount version (if requried)
- wank value...bling factor
Questions
- i appreciate the added strength of these items but for tarmac rally where jumps are few and the roads relatively flat IS IT NEEDED?
- can the standard XM be strengthened?
- would using the std XM with standard rubber block mounts impact handling or anything else?
- would using the standard XM but with a firmer mounting media (poly block?) improve anything WITHOUT shaking the life out of the car?
- is it advisable to modify the XM to chassis mounts so that longer bolts are used that mount through tubes installed within the chassis rail?
I am not interested in chassis mounting the engine.
This is for a Mk1, Pinto, T9, maybe 1-2" lowered.
I just want to put my limited money into the areas that are needed and that will make a difference. I don't want to use various parts just because that is what other people do or that they look nice and shiny in the magazines.
Your help, experience and advise is appreciated.
