Results 1 to 10 of 10
Thread: Dyno tuning
    3,641
    Dyno tuning
    Just about to stick my Escort on the dyno again after changing the exhaust manifold. Last time I just sorted the carb jetting and played with ignition timing, I’ve rejetted the carbs to give a good AFR on the road using a wideband AFR meter but what is the best procedure for dyno tuning that most use ie. ignition first then jetting then cam timing? Each has an effect on the other, last time I didn’t touch the cam timing but may try swinging a couple of degrees each way this time. What are your methods ??
    25,110
    Re: Dyno tuning
    as a rule, because the fueling can be done by reading afr, you put sensible ignition timing into it, sort the fueling out, swing the cam timing/ram pipes etc, at which point you might need to trim the fueling to get it back correct and then finish by finalising the ignition timing
    3,641
    Re: Dyno tuning
    Perfect, thanks Graham.
    Re: Dyno tuning
    What power are you expecting, 172+ @ the wheels?
    3,641
    Re: Dyno tuning
    No idea, made just over 190 when it was on an engine dyno after it was built. Not really chasing a figure to be honest just want the best from it.
    Re: Dyno tuning
    It'll be nice to see an improvement with the new ex manifold, especially in the mid range. It'll be difficult to compare to power figures of the static dyno. Lets hope you have got a good Rolling Road operator that knows his or her job.
    3,641
    Re: Dyno tuning
    For sure, I had to richen the top end after swapping the manifold as it was a tad leaner, just went down from a 200 air corrector to a 190 to give me around 12.8 AFR
    Mechanic DANGERDAVE80's Avatar
    Jul 2008
    Edinburgh, United Kingdom, United Kingdom
    806
    Re: Dyno tuning
    Where do you take your motor for dyno tuning mate?
    3,641
    Re: Dyno tuning
    My mate at Agra in Dundee dyno’d it on their engine dyno when it was built but will be taking it to Sitech in Dunfermline rolling road.
    Jul 2008
    806
    Re: Dyno tuning
    Quite fancy seeing what my one will do, Not that bothered about the numbers just curious really!
