escort mk2 alloy tank diferences
hello to all, im thinking about buying an alloy tank for my mk2. i use twin webers and they are two types of tanks in burton
carb push-on outlets MP1250
carb with -6 outlets MP1251
i dont know what tank i should buy, need some help
thank you!
Re: escort mk2 alloy tank diferences
Either one will do it's just the connections that are different.
what connection should i buy or whats the usualy used tank?
If you intend to use a fuel-hose with clamps then buy the one with the push-on outlets.
If you intend to use the expensive dash6 connections then get the other one.
Tags for this Thread
