Results 1 to 2 of 2
Thread: How to select the correct injector?
    Spanner Monkey Dr Knockers's Avatar
    Dec 2008
    London
    352
    27
    My question relates to a 2.8 cologne EFI lump, which i intend to turbo at a later date, the current injectors need a service(purchased second hand need seals etc) but i thinking i should source injectors the right size for when i turbo it and have them serviced instead.
    I have no clue yet how to start working out the correct size injector for a turbo application?
    Current injectors are Bosch 0 280 150 219 or the Lucus equivalent FDB318
    ratings read
    16 lbs/hr
    cc/min 167
    ohms 16
    hp est each 33
    test pressure PSI 36.3
    Can any body point me in the right directions of a how to maybe, would like to understand how to do this?
    Thanks in advance
    Neil
    Dec 2008
    London
    352
    27
    Re: How to select the correct injector?
    Got a bit further on with selecting injectors now.... its still a bit lacking in concrete knowledge to be 100% confident in selecting!!
    these sites were very useful
    http://www.injector.com/injectorselection.php
    and
    http://users.erols.com/srweiss/tableifc.htm#BOSCH
    thinking about getting
    a set of Bosch 0280150558's
    Flow rate: 42lbs/hr (465cc/min) at 43.5 psi
    Electrical connector type: EV1
    Length: 3 inches, 74 mm
    Diameter: 24 mm
    Orings: Top and bottom, 14.5 mm
    Resistance: 14.5 Ohms
    Will this be over kill? max power for the above injectors is 288bhp, what is the upper most power possible from a 2.8i EFI with a V6T21 on aftermarket management
