Results 1 to 3 of 3
Thread: Limited Slip Diff Movement
    Spanner Monkey haz87's Avatar
    Aug 2012
    Colchester
    226
    Potentially a stupid question, but I've only had the one LSD in my hands so have no comparison. Probably going to be one for anyone who's torn down their own box really..
    Is the "inner" portion of the LSD meant to have play/move about slightly?
    Best pic i can do for now - i mean this bit inside the holes of the outer casing, essentially the bit the two inner CV's slide into.
    Hope that makes sense
    Harry
    Aug 2015
    Leeds
    769
    33
    Re: Limited Slip Diff Movement
    Are you taking about the planet gears where the drive shaft goes? There will be a little play in them, depends what your definition of a little play is tho.
    Aug 2012
    Colchester
    226
    Didn't know the correct term, but yer definitely where the inner cv/driveshafts go. At a guess, I'd say theres around 10deg of play. It feels excessive, but I didn't/don't really know what to expect, hence thought i'd ask about
