Results 1 to 25 of 25
Thread: weber alpha t/bs
    Aug 2005
    somerset
    1,041
    12
    weber alpha t/bs
    Got these today i know there not everyones cup of tea but was going to pay similar money for a carb set up so they were cheap!!What else is needed going to need some cables they have been cut, and ecu is loaded with base map only.Anyone shed some light on model info etc cheers
    Attached Thumbnails Attached Thumbnails DSC_0001 (2).JPG‎
    DSC_0002 (2).JPG‎
    DSC_0003 (2).JPG‎
    May 2009
    chester
    472
    Re: weber alpha t/bs
    i wouldnt of gone with that ecu, a lads just been to mates rolling road after he'd been to alpha/aldon(whoever maps it and charging £300 a time) he had DTA fitted and gained nearly 30bhp iirc. as the timing was backed right off on the alpha set up.
    how much did you pay if dontmind asking?
    Aug 2005
    somerset
    1,041
    12
    payed 740 posted for them i know you cant map them yourself but surely they do the same job as other ecus??
    May 2009
    chester
    472
    the lad went with the dta as its £300 a time to have aldon/alpha map the car, it works but i dont think it will get the best out of the motor though. but someone may know more about it,to give a much more detailed answer
    9,204
    it should get the same results as any other ecu if mapped correctly. the downside is that only alpha dealers can access the software and apparently parts are hard work to source .
    Aug 2005
    somerset
    1,041
    12
    got a dealer not far from me just thought i would give it a go it has a base map loaded already so will have to see only a road car so not interested in ringing every last bit of power out!! will ring him tomorrow see what the prices are what is the norm for rolling road set up?
    May 2009
    chester
    472
    couldnt tell you as depends how much work they do. but the place this lad was going to, was costing him £300 a time!
    Clint's Avatar
    Jul 2001
    932,419
    These ECU's are excellent, the issue is finding someone who can map them is the only issue.... do your engine mods find someone goood and get it mapped once !!!! for a good map £300 is a good price no matter what ECU, it take no longer to map these than a DTA or any other ECU if a) you know what your doing and b) you have the right equipment to live map them..... enjoy
    Aug 2005
    somerset
    1,041
    12
    thats a better response apparantly the base map is quite good i am only going to be running mild road cams so will go from there mailed a firm in cheltnam which i got through webcom can do it no probs at around 2-300 quid
    Aug 2005
    somerset
    1,041
    12
    on my weber loom there is a plug for a lambda sensor my motor is a 20xe (early) which as far as i know didnt have one can i just not connect it or is the ecu "expecting" one?????
    9,204
    you will need it for mapping, get a boss welded into lower end of ex manifold
    Aug 2005
    somerset
    1,041
    12
    cheers where can i get the boss plus sensor?
    Clint's Avatar
    Jul 2001
    932,419
    Can you post a picture of the inside of the ECU please ?
    Aug 2005
    somerset
    1,041
    12
    there you go
    Attached Thumbnails Attached Thumbnails DSC_0001 (4).JPG‎
    DSC_0002 (5).JPG‎
    Dec 2007
    Dubai
    1,678
    29
    I used one of these on my Raceline Duratec, was a good ECU as long as you get it mapped. The other option is if you can get a replacement eprom chip (the one with the white sticker in the picture above) with the correct map from somewhere. Raceline for example had a supply of these to suit their various Duratec and Zetec engine specs
    www.gulfpetrolheads.com
    Nov 2003
    Wirral UK
    6,740
    257
    Quote Originally Posted by jonny View Post
    http://www.efi-parts.co.uk/index.php?productID=177
    http://escort.accelerator.org
    Aug 2005
    somerset
    1,041
    12
    many thanks
    Feb 2005
    Norway
    438
    There must be someone that has found an unofficial way of programming these?
  19. #19
    Clint's Avatar
    Jul 2001
    932,419
    I can live map them completely unofficialy
  20. #20
    Aug 2005
    somerset
    1,041
    12
    tell me more!!!
  21. #21
    Nov 2007
    dorset
    624
    36
    if you still need a lambda boss let me know. i have some.
  22. #22
    Aug 2005
    somerset
    1,041
    12
    need one mate how much we talking?
  23. #23
    Clint's Avatar
    Jul 2001
    932,419
    tell me more!!!
    I started to play with these back in 2001 with my old Orion :
    http://www.turbosport.co.uk/USERS/Co...int/orion.html
    Done loads since, most Weber dealers know very little about how to map cars properly !
  24. #24
    Aug 2005
    somerset
    1,041
    12
    clint dont suppose you could help with this going through the bits today and noticed i dont have the air temp sensor that attaches to the filter base plate if that makes sense?? dont suppose you have any pics around showing this,also if i change the backplate for a pipercross one(as space tight for weber filters) where would the sensor go to cheers.
  25. #25
    Feb 2011
    southport
    CAN YOU STILL LIVE MAP THESE ECU,s ?
