Stack speedo and dash cluster
stack speedo complete with carbon fibre insert panel and a pair of cheap dials not the best, lights and the required speed sensor to go with it sure I've still got the box and instruction dated 2013 speedo has only got about 35 miles on the odometer £200
Sent from my G8441 using Tapatalk
Re: Stack speedo and dash cluster
if someone is interested in the dash surround and small gauges i would like the speedo and sensor
just buy the lot the only value is in the speedo and cable anyway
i dont need the rest and a new speedo is £220 ish
no probs and the sensor wire was £60 on top
already have sensor, thanks anyway
sold thanks folks
