Results 1 to 7 of 7
Thread: Cam recommendation for a road race motor.
    Jun 2018
    VA, USA
    11
    Question Cam recommendation for a road race motor.
    I'm in the US, and building a Duratec for a Pro-Challenge Mustang road racer.
    It's a tube-frame RWD car, running a T5 trans and a Winters quick change rearend, with a race weight around 1900-2000 pounds with driver.
    I called Crane Cams yesterday to ask for cam recommendations, and it seems they have discontinued supporting the Duratec.
    I wonder if anyone could recommend cams and valvetrain for my build.
    The block is a Ranger 2.3, with a modified Forged Ecoboost crank, Molnar Technologies forged rods, and Wiseco 12.5:1 forged pistons.
    Oiling is via a Raceline internal dry sump, with a Concept Racing 1.5 gallon tank, remote filter and cooler.
    The head is from a Duratec 2.5, casting # RF8E5E from a 2010 Ford Fusion, and I have modified the oiling system to eliminate the VCT and feed the front intake cam journal from the main oil feed instead of through the VVT system.
    The head will be fully ported, with 1mm oversize intake and exhaust valves.
    Intakes will be 50mm ITB's, and due to space limitations in the chassis, we're designing a billet intake that will place the throttles as close to the port as possible, and angled up approximately 45 degrees or so.
    I plan to fabricate an airbox over the airhorns, and duct cool air from a remote filter behind the grille.
    I'm aiming for peak power to be around 8,000 - 8,500 rpm, with a redline of 9,000, and would like to see over 300HP if possible.
    I see cams from Kent Cams, and Cat Cams, but don't know much about either company.
    I do like the Kent Cams design, which comes with an adjustable sprocket as standard, and gets rid of the single bolt/friction washer setup, but I need to make sure they offer them in 38 tooth to match my oil pump and crank gears, and chains.
    Anyone with experience, I'd really appreciate your input.
    Thanks,
    David
    Jun 2018
    VA, USA
    11
    Re: Cam recommendation for a road race motor.
    Yesterday I called Kent Cams, and spoke to Del.
    He was very helpful, and based on what I told him about my setup and application, he recommended their D-TEC 80 cams, double valve springs, and titanium retainers.
    I asked about whether the higher lift of their 2.5 grinds would provide a wider power band, and he said the longer duration of the 80 cams would work better at the higher RPM I plan to run, and would also be easier on the valve springs.
    I told him I'd be back in touch to place an order as soon as we have flow numbers on the ported head.
    I'm anxious to see how the 2.5 head flows. Those intake ports look huge compared to the 2.0/2.3 head.
    25,110
    Del has been at kent forever, i used to talk to him about cams 30 years ago!
    Give Paul Gardner Racing Engines a call on 01524 791507. Paul's Rally spec 2.5 Duratecs are similar to what you have in your engine so he would be able to give you some sound advice and maybe even supply you with a pair of cams.
  5. The Following User Says Thank You to Forest_rallying For This Useful Post:
  6. #5
    Jun 2018
    VA, USA
    11
    Thanks, I'll give him a call.
  7. #6
    Sep 2006
    Bedfordshire
    327
    33
    That sounds like an interesting engine build!
    Got any pictures?
    Be good to to see the final results
  8. #7
    Dec 2015
    NH, USA
    86
    They offered you an off the shelf grind for your specialized application in a motor that wasnt a small block chevy? Lol. Find a real cam company. Looks like webbcam will do hard weld on a factory core and grind it to whatever you want or work with you to design a cam. They list MZR hardweld at the cost of $842, no duratec listed so just tell em you have an mzr, same thing.
  9. The Following User Says Thank You to Leafy For This Useful Post:
Tags for this Thread
