Hi everyone, havent posted in ages, still own my escort Although its been sorn for a few years.
Can you fit a line lock valve to the rear brake line, so that you close the valve then you can use the front brakes only to do a rolling burnout ? Or with the line lock closed would you just not be able to push the pedal down? This is with a bias pedal box
thanks
Justin
