Results 1 to 7 of 7
Thread: pipe ends
    Racer Decade Plus User alancdavis's Avatar
    Oct 2009
    cumbria
    69
    2,477
    pipe ends
    How are this type of end fitted to braided fuel pipe ? also a lot of tanks and pumps are push on fitting and not screw on ,,,Totally foxed
    Re: pipe ends
    which end are you referring to? to fit to braided hose you unscrew the red ferrel, screw that onto the braided hose, then screw the hose/red bit onto the blue. you cant use it with push fittings
    Oct 2009
    cumbria
    69
    2,477
    Re: pipe ends
    Problem I have is my tank and pump has push on fittings
    4,889
    Re: pipe ends
    Then use other fittings.
    3,241
    Re: pipe ends
    So obvious when you think about it LOL!
    Bodger Duffer's Avatar
    Jan 2014
    West Sussex
    198
    27
    Re: pipe ends
    Also in this day and age, I'd make sure that you are using teflon lined fuel lines, especially as (as presume this is on the Fiesta) the fuel lines are in the car. If you just use braided rubber hoses, you will get petrol fumes in the cabin
    Aug 2015
    Leeds
    767
    Re: pipe ends
    Quote Originally Posted by alancdavis View Post
    My tank also has push fit connectors, I used a braided hose from tank to fatec fuel pump also with a push fit connector, the outlet of the pump was changed to a an fitting like above then went from there
