Results 1 to 19 of 19
Thread: Xflow rocker noise
    Jul 2015
    shropshire
    204
    26
    Xflow rocker noise
    Hi all any help appreciated.1700 xflow.1300 pistons.stage 4 race head. Twin 40 dellortos 244 cam twin chain double valve springs steel rocker posts.theres hell of a racket coming from i believe rocker area.there adjusted as kent spec for cam.what would cause this noise ie wrong post size. Not useing steel shaft.push rod legnth.other than noise engine pulls v well and set up on rollers making 141bhp@6400 revs 124ft torque.any ideas as the noise is unbearable its that bad.plus you cant hear noise when on rollers or from outside.and i can soften noise over certain revs in diff gears.cheers
    25,110
    Re: Xflow rocker noise
    check valve to piston clearance!
    Jul 2015
    shropshire
    204
    26
    Pistons pocketed! But how can i check?
    25,110
    on an x/f its easy, pick a cylinder, get it at tdc with valves on overlap, ie slightly open. loop a ring spanner over the tappet adjuster and check to see how much further you can open the valve by lifting the end of the spanner
    Jan 2008
    Up the garage
    2,775
    218
    Tin rocker cover hitting the rockers? Tin rocker cover letting noise through?
    Thick aluminium rocker covers can mask some of the noise.
    Oct 2008
    whitley bay
    2,436
    89
    Worn rockers?
    Hexham and District Motorclub
    25,110
    rockers quite often hit the inside of alloy rocker covers
    Jul 2015
    shropshire
    204
    26
    Thanks for all the help/ideas guys i origionly thought about rockers hitting cover i had alloy vulcan one swaped to tin no diff and no marks on cover.thanks graham il try what you surgest. Any ideas why noise would only be under load not even at full throttle and like i said does not make this noise on rollers just on road
    Cam comes on around 2800 revs and noise can ease off then???
    May 2007
    762
    pockets in the pistons need to be wide enough for big valves, not only deep enough … I would take the head off to be sure (if all other Obvious things are checked, 244 needs a lot of play between valve and rocker also, I have given more play then stated by KC)
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Quote Originally Posted by Painter an View Post
    If it doesn't do it under load or on the rollers could it not be a vibration from something else and not the engine atall?
    Jul 2015
    shropshire
    204
    26
    Rockers set at 22 and 24 what would you surgest?
    Jul 2015
    shropshire
    204
    26
    Quote Originally Posted by davemk1 View Post
    Iv thought that as well as changed exhaust manifold thinking might be blowing.any ideas what could be? I cant understand if i sit in and rev it its not there but as soon as pull off it is.its really loud and anoying not to mention worrying.cheers
    May 2007
    762
    22 and 24, what does KC suggest ? inlet seems big clearance, outlet sounds right to me ?
    Jul 2015
    shropshire
    204
    26
    Those are kc figures for 244
    3,237
    If it's only doing it moving and on the road it would tend to move the diagnosis to transmission / axle / suspension!
    Jul 2015
    shropshire
    204
    26
    I know noise travels etc but def under bonnet area
    I read some where about flywheel bolts loose but not sure what would sound like or if you could feel it.
    Thanks for all the ideas tho guys
    Oct 2008
    whitley bay
    2,436
    89
    Just a thought i had a noise when I rebuilt mine which was a bolt and dropped between the bulkhead and bell housing only made the noise at 2000rpm
    Jun 2014
    leeds
    58
    127
    harmonics and resonance. i had a similar spec motor that rattled at a certain rev range in a certain gear. wouldn't be too worried about it too much if all seems ok. if your that bothered take the head off for a look
  19. #19
    Jul 2015
    shropshire
    204
    26
    Quote Originally Posted by fatboy slim View Post
    Yer i know what you meen.funny tho as before this engine the one i had before was 1700 with 1300 pistons but only 224 cam gt head twin 40s which made a similar sound which is why im leaning towards it not being engine. Going to see if i can upload sounds on youtube thanks again
