From what I can understand a fuel pump is not permited to be located in the cabin area of a car unless it is in an enclosed box which I assume needs to be fire proof,,,,Any suggestions as to where I can get a suitable box
Also I beleve the fuel cell is not allowed in the current position and would look to suggestions to resolve this
simplest solution is bet a big alloy box made which you can rivet/screw to the floor with a lid/access hatch, which if it has a seal of some sorts would be acceptable. but i dont think you can buy such a thing off the shelf, most i see are clearly homemade, or knocked up by a metal fab company
edit, you could make the box yourself from sheet alloy ( or even steel) if you can fold corners and weld/rivet together.
well I guess thats one solution ,,,,Thanks for all the positive advice ,,,much appreciated.
Or put it under the floor? Only cost you 4m of copper microbore pipe and some P clips!
Or make a firewall separating the boot and fuel tank area
