Results 1 to 8 of 8
Thread: 24v Capri Problem
    Sep 2016
    Norway
    18
    24v Capri Problem
    Hi. I have a mk3 capri with a 24v engine fitted. I finally finished fitting the engine and everything, and then on the first test run I found that when you press the gas pedal, it won't "fly" away, its holding back for some reason.. Its running nice on idle, but when you rev it, it sounds almost like it's not firing on all cylinders, but if you are veery gentle with the gas pedal, it revs normally.. Any ideas?
    Many thanks.
    Sep 2016
    Norway
    18
    Re: 24v Capri Problem
    Have offcourse checked coil, sparkplugs, leads, Maf, tps++
    4,887
    Ignitiontiming?
    Sep 2016
    Norway
    18
    Ignitiontiming?
    With Edis? It idles really well, and if you keep it at example 3000rpm, it's also running on all 6 nicely.. Its only when you try to accelerate it doesn't work...
    4,887
    Meant have you checked ignitiontiming (advcance) when accelerating?
    9,200
    24v Capri Problem
    Sounds like it's lean maybe. ?
    Check fuel pump and filter etc as I guess map is standard and fixed.
    Sep 2016
    Norway
    18
    Have now changed the fuel pump to a bosh 044, and checked the rest of the fuel hoses etc.. Still the same. If this was a turbo powered car I would say its running lean..
    Mar 2009
    sussex
    148
    have you got a timing gun?
    Check whether you are gettiing any movement in timing. The EDIS can go into limpmode to get you home by limiting the timing to 10deg if its not getting the right signal from the ECU
