Results 1 to 10 of 10
Thread: Thackeray washer issue
    Spanner Monkey Kmp's Avatar
    Feb 2009
    Burnham on sea
    390
    Hi all,
    i am getting some bits together to put a pinto in, later in the year and I am currently setting up some twin 40’s to go on a manifold. I have Misab rubbers between the inlet manifold and carbs, reading online the Thackeray washers should have about a .040 thou between the coils Of the spring when tightening them up.
    how ever - the washers I have, are very tight at 0.40 thou out of the box, let alone when tightening them up.
    is it best to buy a certain make of washer to get the right load on the carbs?
    thanks
    kris
    25,116
    Re: Thackeray washer issue
    as long as teh carbs can move slightly your be fine, so just dont do the thackeries up solid
    4,892
    Get the proper Thackeray washers.
    3,641
    I prefer the cup washers and rubbers personally
    4,892
    Me too.
    2,659
    268
    Like these.
    https://www.ebay.co.uk/itm/WEBER-DCO...cAAOSwYH5WB-Mk
    They just replace the Thackeray washers.
    3,641
    Yes mate, they are much better
    Feb 2009
    Burnham on sea
    390
    Thanks for the advice, I have ordered some from fast road cars, is there a knack to tightnening them as to make sure they’re not over tight. Never seen them before.
    Kris
    3,641
    Not really, as long as the faces of the two cup washers dont make contact and there is a clearance between them, the carbs will float slightly, you basically just dont want the carbs solid on the mounts or the fuel can froath in the float chamber, grab the carbs with both hands and make sure they flex a little - job done.
  10. The Following User Says Thank You to Erikmex For This Useful Post:
    Kmp
  11. #10
    2,659
    268
    Good point I didn't realise that tbh, as I thought it was more related to making sure you had no air leaks around them, but if that were the case then just tightening them up until solid would cure that but it would then allow the fuel to froth in the float chambers...
