Results 1 to 27 of 27
Thread: 1975 Toyota Publica (kp30) Restoration and modify
    Jan 2010
    Ireland
    36
    Doing a bit of work on this '75 Publica. Like most 70's Toyota's rust is a huge problem made worse by bodged repair work over the years.
    First job was to strip it down get it on a spit and media blast the underside to see what was what. Naturally it was worse than originally expected. The car is eventually going back on the road with pretty standard looks with the exception of arch extensions and bigger wheels. Rear suspension, diff and gearbox is all AE86 twin cam corrolla stuff with the engine coming from a Toyota AE111 Levin - 1.6 20 valve Blacktop on factory individual throttle bodies..!!
    The engine was never designed for rear wheel drive configuration with the oil filter for example sitting exactly where an engine mount needed to be so a remote filter kit was used, pitman steering linkages and brake master cylinder are also in the way of new engine/gearbox fitment. Luckily the factory sump clears the cross member. Power steering and A/C pumps where removed. I had to make up custom engine mounts but it is a very tight squeez lenght wise in the bay, the front pulley and bulkhead both needed modification to fit as the distributor and thermostat housing both need to protrude about 2 inchs past the bulk head.
    Transmission tunnel has been enlarged also to allow the fitment of a 5 speed T50 gearbox.
    Pit Crew Decade Plus User raymondmarble's Avatar
    Sep 2005
    Dundee
    1,029
    116
    Re: 1975 Toyota Publica (kp30) Restoration and modify
    Absolutely fantastic Stub!
    I love things that are a bit different and few people have. This is right up my street! I'll be watching it progress!
    Tyre Kicker clinchy's Avatar
    Dec 2009
    Newbury
    36
    22
    nice little project
    does the AE86 come with an LSD?
    luke.
    HONDA CIVIC 1600cc SOHC TURBO
    Jan 2010
    Ireland
    36
    Quote Originally Posted by clinchy View Post
    nice little project
    luke.
    It was a factory optional extra... seems to have been more popular as an option in japan though with quite alot of the import cars having one fitted.
    Spanner Monkey Mick The Cabbie's Avatar
    Mar 2006
    away with the fairies
    422
    I like these
    Thats a nice little project you have on the go!!.
    What colour are you going for??
    1972 MK1 Escort 2.0...1969 Mk1 Twincam Escort...1964 Anglia Van...1982 Starlet YB turbo
    May 2006
    southend
    47
    575
    love these like the colour to
    Jan 2010
    Ireland
    36
    Bit of an update......now appears a rwd escort or Anglia rear axle will be used which ever is the best width to suit the car.
    A few rust repair pics of the drivers side bottom of the A pillar and sill.
    Honda Vtec alloy rad and push fan as there is no room for a pull fan in the bay, rad has been mounted 30mm more forward than the standard rad also. Braided lines are for a thermostatically controlled oil cooler and filter relocator.
    Old Focus 1.8 discs used to mock up the new braking system, shown beside the original 200mm solid discs, I'll use new discs and rebuilt focus calipers for the finished version.
    You can see the Mk2 fiesta steering rack mounted on the engine cross member, needed to ditch the original pitman linkage system as it fouled on the new box and exhaust manifold.
    Trial fitting the Mk2 Escort bias pedal box, may ditch the original floor hinged accelerator pedal too.
    Trial fitting the new 909 spec fuel filter and M3 fuel pump.
    Nov 2003
    Wirral UK
    6,740
    257
    This is going to be awesome
    http://escort.accelerator.org
    Sep 2005
    Dundee
    1,029
    116
    Keep up the progress! We'll motivate you
    Jan 2010
    Ireland
    36
    Fabricated and re-routed steering column mocked up, needed to be re-routed to allow clearance for the mk2 escort hydraulic pedal box, Only about 6 inchs of the original upper colunm remains, the original pitman linkage system has been removed due to lack of spares and clearance problems with the gearbox and exhaust and has been replaced with a modified XR2 steering rack.
    Sep 2005
    Dundee
    1,029
    116
    Thats a lot of steering joints!!
    Looking good though mate, doesnt look too far away from its first fire up?
    Keep the pics coming!
    Jan 2010
    Ireland
    36
    There needed to keep it as close to the inner wing as possible till it drops below the cylinder head. Next on the list is a cover for the steering joints and bearings to keep out dirt and crap, then fab a plenum for the throttle bodies.
    Sep 2010
    Brunei
    Hi there..I'm new here. Is there a very big chance if I want to just overhaul the actual engine of the Toyota 2K engine. Unfortunately, it's difficult for me to find the overhaul kit for this engine type. Would you guys by any chance help me to find where to buy the overhaul kits?
    Cheers.
    hope to hear from you all soon.
    Jul 2002
    Bedfordshire
    1,672
    108
    Your local Toyota dealer should be able to supply parts for the 20 valve engine, even though they arent available here in the UK, only on import, my local dealer can get gaskets, seals etc
    Jan 2010
    Ireland
    36
    Laying out the 20V engine, T50 box and AE86 prop shaft inline with the engine cross member to get a ball park figure of how much the prop needs to be shortened, need to find out the dimensions of the diff carrier though.......
    Very rough mock up of the hybrid rear end.....narrow (1108mm) English axle casing with KP30 leaf springs and ARB.
    Throttle bodies removed from manifold so the short trumpets can be welded on.
    Standard Toyota 1000 strut and brake set up.
    45 mins later......stripped, spring platform cut off and ready for blasting.
    Narrow english axle stripped and ready for blasting.
    24 hrs later........coilover conversion using a modified mk2 Escort kit and 260mm Ford discs machined to fit the toyota hub, just need to make a bracket to fit the Focus calipers.
    Jan 2011
    Sarf Rugeley
    584
    32
    Great work m8. Im doing the same conversion in a Mk2 escort. Just wondering what M3 fuel pump are you using there.
    Are you using a aftermarket fuel pressure regulator?
    Jan 2010
    Ireland
    36
    Quote Originally Posted by bunta20v View Post
    Its a Sytec pump designed to replace the external bosch pumps used by performance bmw's, I've used a few of these in previous conversions as they are simple to wire, have a flow rate of 130+ litres per hour and fairly cheap at around €65.
    For now the engine will run as standard so I'll keep the factory FPR.
    Part of the furniture Decade Plus User Ratters's Avatar
    Mar 2004
    Bristol
    8,648
    75
    nice bit of work going on here mate
  19. #19
    Jan 2011
    Sarf Rugeley
    584
    32
    Quote Originally Posted by STUB View Post
    Thanks for that. I think i have found the same one on ebay. I didnt get the FPR with engine so is there one that you recommend. Do you use braided lines throughout?
    Also in one the pictures there is a white filter thingy (i think) that goes to the map sensor on the throttle body. Do you know where I can get this from as im missing it from my engine. Sorry about the questions, just trying to get as much info on this conversion.
  20. #20
    Jan 2010
    Ireland
    36
    Front brake Caliper set up finalised, made this bracket to mount some mk6 Fiesta Calipers on the mk1 Focus discs.
    Had a set of 240mm solid discs for the rear machined to match the front vented discs
    Modified a set of long U-bolts so I can bolt the anglia axle to the toyota spring platforms through a 50mm lowering block
    The rear axle (1959 Ford Anglia) half shaft flanges were turned down by 3.5mm so the new cross drilled and grooved discs will fit over them. Originally the wheels were bolted on to the flange surface but fitting the discs will space them out by 10mm so I have some longer wheel studs ordered.
    Cut a hole in the inner wing to allow fitment of a cold air feed to the new air box I'm fabricating for the engine.
  21. #21
    Spanner Monkey FrEdOoOo's Avatar
    Mar 2009
    Portugal
    384
    25
    Very nice project and top job!!!
  22. #22
    Spanner Monkey alex savill's Avatar
    Sep 2006
    Harlow
    29
    214
    Well that will look the part when its finished
    Any updates to wet our appetites?
    Restoration Wendy
  23. #23
    May 2011
    torquay
    36
    20
    any Update's?
  24. #24
    Jan 2010
    Ireland
    36
    Got brand new front shock inserts (36 year old parts) from Japan courtsey of a very helpful Toyota parts manager.
    Dont look like much but these machined spacers were essential to make the Ford/Toyota back end fit together properly.
    Rear axle almost complete now, rear disc conversion done just need to weld on the watts linkage and then paint it.
  25. #25
    Sep 2005
    Dundee
    1,029
    116
    Has it really been so long since this was updated?? How is the build going? Looking forward to seeing it!
    Please 'Like' us on FB!
    https://www.facebook.com/pages/Jana-Kitchen-UK/393933930736835?ref=hl
  26. #26
    May 2006
    southend
    47
    575
    Love it I want one !
  27. #27
    Mechanic oxb1l's Avatar
    Sep 2007
    A, A
    550
    Did this get finished ?
