ST170 Head Cat Cams Zetec Block, Wossner, DTA ECU Loom, throttle bodies etc.
ST170 Head ported and polished by Andy at ALD, cat cams, vernier pulleys VVT delete. Just had a full refresh and reshim £750 ono
ST170 Block, 88mm Wossner 12/1 high compression pistons, Williams racing rods, rwd sump, oil pump new shells etc. Done less than 1000 miles since build. £2200 ono
Bogg bros manifold with 2017 Honda throttle bodies, tps, fuel rail etc £350 ono
DTA S40 ECU with map for above engine complete with aircraft quality loom £700 ono
pm me for pictures. Engine can be assembled if required. It made 192 Bhp on rolling road with safe map.
Change in direction with project means no longer needed.
Re: ST170 Head Cat Cams Zetec Block, Wossner, DTA ECU Loom, throttle bodies etc.
Head sold, block sold, ecu and loom sold
Throttle bodies, manifold tps fuel rail ready to fit to zetec/st170 £300
