Hi all, so ive finished my turbo xflow and had a run in map installed, after that they did a quick power run @8psi and this is the power weve got so far...
1980 Mk2 Sport xflow Turbo
Sorry, forgot to give some info on the motor.
Its a AX block, CA18DET pistons, L16 rods(cleaned up), std crank, o-ringed + steel headgasket, ported & polished head, duplex timing gear and chain. T3 turbo, homebuilt intake and turbo branch, external wastegate. The boost will be set @14,7psi daily and 19,11psi on race days...yeehaa!!
Good stuff
what will be the expected power when it's all finished ?
L8r Bill
