type 2 1300e or sport gearbox required also 2 pc propshaft
ALLWAYS EXPECT THE UNEXPECTED
One type 2Gearbox forsale
Hi Tawny, I've got a 2 piece CV type propshaft - would it do for you? It's for the Type 2 gearbox with the Type 2 nose and correct splines for the Type 2 output shaft. It has a large flange prop mounting (106mm) which some mk1's came with if I remember correctly (I'm guessing your car is a mk1 if it's a 1300e?). Not sure if it came from a mk1 or mk2 though. I'm guessing same length etc.
I'm only up the road to you so easy to come and view. PM me if interested and I can get some photos for you.
