2x Two Door Escort MK1 For Sale + Parts Job Lot
Dear All,
5 years ago I bought 2 Escort MK1's with the intention of restoring them, however due to other commitments along the years I never started these projects. Fast-forward to this year, I went through some life changing situations and decided that My Escorts should be sold and sent to a new home where they hopefully will be restored as they deserve to be!
I have one 1969 2 door Model with Round Headlamps and RS Front Wings
- 1298cc Cross Flow Engine
Car has some usual rusted parts such as front floorboards and pillars, but all the body panels that require replacement are included with the car itself. Apart from the mentioned areas, the car is found to be in a very good condition thus it makes a great solid base for a restoration. Most parts are still with the car and only few bits are missing.
For more detailed view of the car please follow the below link to view the pictures.
1969 Escort Mk1 1300cc Pictures (Click to View)
The other Escort is a Late 1974 2 Door Model with Squared Headlamps and standard front Wings
- Car used to have a fitted Toyota 1498cc Turbo 1N Diesel engine, nut I got rid of this engine and Purchased a 1998cc Pinto Engine for this car.
Car has some usual rusted parts such as front floorboards and pillars, also It has some rust under the right bonnet hinge. Apart from the mentioned areas, the car is found to be in a very good condition thus it makes a great solid base for a restoration. Most parts are still with the car and only few bits are missing.
The Car comes with the following upgraded parts- Rear Capri Seat
- GT dashboard
- Front Half quarter Bumpers
- Sierra 5 Speed Box
- Front Escort MK5 Seats
- Mini Light Alloy Wheels
- Front Adjustable Suspensions
- Front Disc Brakes
- Capri Power Break servo
1974 Escort MK1 2000cc Pictures (Click to View)
Furthermore to the above Mentioned I also have loads of spares to go with these cars which will certainly facilitate the restoration process for the new owner.
These parts are :
Engine Related- 1300cc 711M Extra Engine
- 1100cc 681F Block Extra Engine
- 1300cc +0090 711M Extra Engine (Freshly Built Never Started)
- - 711M Block
- Freshly Faced Block and head
- Freshly Cut Valve Seatings
- New Phosphor Bronze valve guides
- Ported Head
- Lightend Flywheel
- Polished Connecting Rods
- Polished Crankshaft
- New Main and Big End Bearings
- New Original Ford Piston Rings +0090
- New Gaskets and seals all round
- New Clutch
- New Oil Pump
- Kent 244 Camshaft
- Duplex timing sprocket
- New timing Chain
- Kent Double Springs
- New Burton Big Racing Valves
- New UFI Oil Filter
- 4in1 Manifold
- Quaife Quick Steering Rack
- Extra prop Shafts
- 1600cc Gearbox
- Extra Carbs
- 6x 1100cc Conrod Sets
- 2x 1600cc Conrod Sets
- Extra Fan And Radiator
- Extra Diffs
- Several Front Windscreens
- Several Rear Windscreens
- Several Front windows
- Several Rear windows
- Extra pair of Standard Wings
- 1x Extra RS Style Wing
- Extra Passenger Side Door
- Extra Original Bonnet
- Extra Original Boot
- Many FORD + Escort Badges
- A pair of genuine Ford Oval badges
- Extra pair of Squared Headlamps
- 2x Extra rear tail lamps
- 2x Squared headlamp front grille
- 2x Round headlamp front grille
- Extra Front And Rear Bumpers
- Set of 4x Wolfrace Wheels
- 2x Sets of 8x MAS Fiat light weight alloy wheels PCD108
I've tried to mention most of the parts however the list of parts is impossible to remember, anyways I'll promise to hand over all of the related escort/ford parts to the new owner as I don't need them anymore.
My intention is to sell these two cars as a lot with the inclusion of all the parts I have mentioned above. Kindly note that the cars are situated in Malta and I willing to sell them overseas with the new owner taking care of any additional shipment cost.
I know how rare most parts are nowadays and knowing that both cars have a good solid base I am looking to sell the car and parts lot at the price of : £25,000!
Please do not hesitate to ask for questions should anything is unclear.
I'd prefer to be contacted on my phone (Whats App or Call) rather than private message on the site as I am usually with limited internet connection.
Contact number : +00356 79391538
Please no time wasters and scammers!
Thanks for Viewing!!
Regards,
Gary Grech
