Results 1 to 3 of 3
Thread: HELP WANTED: - Cosworth Engine Build Woosner Pistons
    Apr 2017
    Hampshire
    Hi All
    after some advise currently collecting part for my 200 block cosworth build and i have got some question.
    what are peoples thoughts on Woosner pistons? heard they suffer from piston slap, but i would have thought that would be to do with the bore/fitting and not the pistons themselves.
    also i'm aiming for 500-550BHP, i currently have a 2wd head would there be any benefit in fitting a 4wd head or will the 2wd cope just fine.
    one fine thing inlet. i will be running eight injector, but would a swedish manifold, Hart or RS500 with spacer be better
    Oct 2011
    965
    Re: HELP WANTED: - Cosworth Engine Build Woosner Pistons
    Following
    Jun 2007
    Whitley Bay
    3,437
    81
    With better turbo's now and more affordable aftermarket ECU's could you not have a standard spec cosworth YB make good power without the need aftermarket inlets, and all these bolts on bits?
    Screaming 1300 mexico rep
